Date/Time: Mon, 24 Feb 2025 15:34:13 +0000
nasdaq 100
View Count: 1918
[2018-08-08 10:48:38] |
User583898 - Posts: 7 |
Hello. Can´t find the symbol "nasdaq 100" (NAS100 actual price 7.462,65) Thanx from Austria |
[2018-08-08 17:53:44] |
Did you want the CFD symbol or the actual cash index symbol and did you require real-time data?
[2018-08-13 09:46:59] |
I dont know the difference between CFD symbl and actual cash index symbol. And what do you mean with real time data? I mean the symbole what most of the MT4 broker provide as "NAS100". eg. Sierra chart says GDAXI to GER30. By the way, i only use Sierra chart for info, especially the Value Areas an Volume and i´m not connected with e.g LMAX. Hope you understand what i mean and i feel sorry for being clumpsy, but everything is a bit new to me
[2018-08-13 17:32:50] |
You can use the CFD symbol for real-time data. You can find it in File >> Find Symbol>> CFD. It is: NAS100 For volume analysis you will want to use a futures contract which currently is NQU18. For both of these, you need to first follow the instructions here to set Sierra Chart to use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service You will receive real-time data for the CFD. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-13 17:33:22
[2021-03-15 15:54:50] |
Sargon Petros - Posts: 57 |
What is the difference between the cash symbol and cfd symbol? For some reason I don't get prices for the Nasdaq cash symbol but I do for the SPX
[2021-03-16 02:39:21] |
For information about the CFD symbol, refer to: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
