Date/Time: Sun, 24 Nov 2024 13:35:39 +0000
Pullbck Bar _ A new Chart Bar
View Count: 2393
[2013-10-20 08:41:58] |
Moti - Posts: 63 |
Please Help build this bar , it based on Number bar Pullback numbers show below and above the bar , and for day trading it is very useful. Please help to create a bar chart that will open a new bar after pre defined bid/ask delta From every New price Low recount the ASKV- BIDV, if ASKV- BIDV equal to (+250) Green bar close , open a new bar From every New price High recount ASKV- BIDV, if ASKV- BIDV equal to (-250) Red Bar close , open a new bar Thank you, Moti |
[2013-10-22 21:57:51] |
We have something similar to this. It is Delta Volume Bars: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-31 21:22:26] |
Moti - Posts: 63 |
Hello, I believe I wasn't precise in my request, If " Number bars- old" study when visible " pullback ask/bid volume difference " AND Chart setting> "advanced settings" and check box " historical pullback data" >( Pullback or Cot or None), We receive under & above the bar ON the chart the two Pullback numbers How Can I display these two numbers ON the table of " NUMBERS BAR CALCLETED VALUES " study ? Thank you, Moti Date Time Of Last Edit: 2013-10-31 21:23:32
[2013-11-01 04:25:58] |
We understand. This data is only displayed above and below the Numbers Bars themselves. We will see about adding it to the table. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-01 17:44:37
[2013-11-01 09:25:18] |
Moti - Posts: 63 |
SC Support, I will like to acknowledge you for the quick response and your professional service, Please advise if you about to add this number to the table soon, This will avoid complex work with spreadsheets and charts, About my request for Pullback display: Have this information can displayed real time in a spreadsheet ? If yes please guide me how to do this. Thank you, Moti |
[2013-11-01 14:21:18] |
Al SC Developer - Posts: 434 |
In ver 1041, there will be two new subgraphs in the Numbers Bars Calculated Values study: * High Pullback Ask/Bid Vol Diff * Low Pullback Ask/Bid Vol Diff |
[2013-11-01 17:45:36] |
All of the Subgraphs in the Numbers Bars Calculated Values study are outputted to a Spreadsheet when using the Spreadsheet Study and that study is on the chart. Therefore, this is a method by which you can view the data on a Spreadsheet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-01 17:46:05
[2013-11-06 15:00:25] |
Moti - Posts: 63 |
Thank you, Any approximation date for version 1041 release? |
[2013-11-06 16:46:20] |
This is out now. Update with Help >> Download Prerelease.
