Date/Time: Tue, 21 Jan 2025 07:22:00 +0000
Ninjatrader brokerage connection
View Count: 1526
[2018-08-07 11:31:18] |
1zach4 - Posts: 10 |
I am a ninjatrader brokerage customer, is it possible for me to use Sierra Chart and use my ninjatrader continuum connection for data in SC? If so, would I still be able to trade from the ninjatrader dom while using SC at the same time?
[2018-08-07 17:38:50] |
If your ninjatrader brokerage account is setup through the CQG system, then follow the CQG setup instructions here CQG Trading Platform Service: Setup Instructions If so, would I still be able to trade from the ninjatrader dom while using SC at the same time? CQG does not allow two connections at the same time to the same Username. But for further help with this contact your broker.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-07 17:39:27
