Date/Time: Tue, 21 Jan 2025 07:41:39 +0000
% scale on comparison chart
View Count: 1011
[2018-08-06 03:19:08] |
User472677 - Posts: 356 |
How to have a % scale on y axis when comparing several symbols to see the % difference between the performance of these symbols. Using the overlay study. I can not figure out how to get % scale znd show the % move from the beginning for each symbol. The beginning point should be zero%. I can get the price on y axis but I want % |
[2018-08-07 11:51:08] |
Please reply.you are normally good about quickly replying.
[2018-08-07 21:44:43] |
We needed some time to review this. This is going to be the study you will want to use: Percent Change Since Open By default it will display a percentage. And we also need to update the documentation in the last section to explain how to do this for multiple symbols. That documentation is somewhat out of date. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
