Date/Time: Tue, 21 Jan 2025 04:05:18 +0000
error loading chartbook
View Count: 966
[2018-08-05 21:02:39]
YMllc - Posts: 36
Log below, says it cannot find a chartbook, but the .cht file is in the Sierra Chart "Data" folder.
Chartbook file not found: C:\SierraChart\Data\MainChartbook.cht | 2018-08-05 15:59:19 *
Chartbook file not found: C:\SierraChart\Data\MainChartbook.cht | 2018-08-05 16:00:03 *
[2018-08-06 16:20:49]
Select File >> Open Chartbook. Do you see the Chartbook listed there?
Check to make sure that your default data folder is set to where you think it is. You find the information on this here:
General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths)
