Date/Time: Tue, 21 Jan 2025 04:15:49 +0000
Volume At Price Threshold Alert V2 not limited to a single bar
View Count: 894
[2018-08-05 10:19:49]
User993113 - Posts: 74
I'm looking for a visual indication marker when Total Volume at any price level within a fixed time period exceeds the specified threshold.
The closest solution that I could find is Volume At Price Threshold Alert V2, but it is limited to the current bar, while I'm looking for a bracket .
By bracket threshold fixed time period I mean to limit the bracket to this period. The bracket is just an abstraction representing the most recent seconds that are having in total the time period equal (or not exceeding) the specified value of the bracket threshold fixed time period parameter.
The problem with the Volume At Price Threshold Alert V2 study is that if the Total Volume at any price level within a fixed time period exceeds the specified threshold between two or more bars , I can't get the visual indication.
Thank you
[2018-08-05 20:19:40]
This does not make sense to us. Volume At Price Threshold Alert V2 does provide a visual indication on each chart bar for each price level that exceeds the set Threshold.
Or maybe we are misunderstanding what you want to do. Maybe you will want to increase the time frame of the chart bars.
Date Time Of Last Edit: 2018-08-05 20:20:42
[2018-08-06 12:21:44]
If I increase the time frame the problem is still here.
What I need is to scan the last X chart bars, not only one by one.
[2018-08-06 16:38:07]
You will have to do your own custom development to accomplish what you want. Refer to this page here about modifying that existing study:
How to Build an Advanced Custom Study from Source Code
