Date/Time: Tue, 21 Jan 2025 04:13:20 +0000
Market Profile Chartbook for Crude Oil (CL)
View Count: 2077
[2018-08-04 13:50:14]
User94606 - Posts: 327
Looking for a market profile chartbook specifically for crude oil (CL). I am currently using a market profile chartbook (see attachment) for e-mini (ES) but when I changed to CL, the display does not work correctly and I do not know how to fix it. Any help is greatly appreciated.
attachmentMP_RTH_ETH.cht - Attached On 2018-08-04 13:47:22 UTC - Size: 71.48 KB - 736 views
[2018-08-05 06:19:31]
Use the attached Chartbook. We made some changes to make the visible view proper. We set an Automatic Scale Range. And set the number of ticks per letter/block to 5:
Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks
Date Time Of Last Edit: 2018-08-05 20:23:37
attachmentMP_RTH_ETH.cht - Attached On 2018-08-05 06:18:58 UTC - Size: 53.39 KB - 884 views
[2018-08-05 14:28:15]
Thank very much for your help. Some follow up questions:
1. Where did you the Automatic Scale Range? I looked for this setting and could not find it
2. in the /ES chartbook, the chart displays the overnight session in a shaded color, how can I replicate this feature in the crude oil chart?
[2018-08-05 20:22:49]
1. Refer to this page for instructions to change the Scale Settings for the chart:
Chart Scale and Scale Adjusting
2. Use the same study that you did on the ES chart. We just had removed it for testing purposes so we did not get a confusing display. So this would be the Time Range Highlight study.
