Date/Time: Tue, 21 Jan 2025 03:57:52 +0000
SOFTWARE UPDATES.
View Count: 681
[2018-08-03 11:30:54]
User725605 - Posts: 60
When I update software I remain at version 1722.
Current version is 1785.
How do I get to 1785?
Please advise.
[2018-08-03 11:44:54]
Xfanman1 - Posts: 320
There was a problem with the update around your current version. Instead of updating through the application as you normally do. Look in the Sierra Chart folder and use the SierraChartFileDownloader.exe program to download and install the current version.
Once you’ve updated to the current version your updates will work from within the application as they always have.
Scott
Date Time Of Last Edit: 2018-08-03 11:45:47
[2018-08-03 12:48:04]
Xfanman.
I followed your good instruction and my problem was resolved successfully.
Thank you for your kind help and good advice.
John
