Date/Time: Tue, 21 Jan 2025 04:06:47 +0000
Quote Board - Attach/ Detach
View Count: 1422
[2018-08-03 08:29:29] |
nicktrader - Posts: 730 |
If you use the option "Attach" you can move the QuoteBoard outside the workspace. Is it possible to give it the same configurations as for a chart window. Especially if you set a chart to full screen mode and the Quote Board is placed inside the workspace, the Quote Board overlays the chart. |
[2018-08-03 18:07:33] |
We are not fully sure we understand what you are asking for, but in general the answer is that the Quote Board cannot function in the same manner as Chart Window. These windows are created differently in order for the Quote Board to be a floating window. With regards to the Quote Board, you have the options for Attach/Detach as well as Always on Top. Be sure you have these set in the manner that you want for your setup. You will find the documentation for these here: Getting Quotes: Attaching and Detaching Quote Board Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
