Date/Time: Tue, 21 Jan 2025 04:01:36 +0000
ACS safe mode enabled
View Count: 897
[2018-08-02 21:23:03] |
User45578 - Posts: 50 |
Hi,how i can the shut down of "AC safe mode enabled "to get my all complementary studies
[2018-08-03 00:06:41] |
This is explained here: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-03 09:27:54] |
I want to choose mine own studies how i can change:ACS Safe Mode Ebnabled,with this mode i cant get mine own studies |
[2018-08-03 16:30:29] |
On the Login window you need to uncheck Safe Mode. Refer to this section here: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
