Date/Time: Tue, 21 Jan 2025 07:39:37 +0000
show studies scale
View Count: 804
[2018-08-02 18:39:29]
User1990 - Posts: 49
I am wondering if there is a way to still show a study's scale on the right after changing its scale from automatic to user-defined? Also, is there a way to change the display format for studies' scales to be different than that of price? for example, FOREX displays scale in the format of .000 so Volume study in another region also displays X.000 is not only unnecessary but also takes up a lot of space on the right border.
Thanks a lot for your help.
Elaine
[2018-08-03 01:53:33]
Yes it still should be displayed.
Set the Value Format as you require:
Chart Studies: Settings and Inputs Tab >> Value Format
[2018-08-03 12:41:33]
Not really, setting the scale from automatic to user-defined somehow cancels out scale display. My right scale becomes blank.
Also, the value format link you sent doesn’t seem to do anything for scales, only how values are displayed when using show values on the subgraph page to display CURRENT study values. At least that is how it seems to be working on my end. Not sure if there is something I am doing wrong.
[2018-08-06 18:04:42]
Attach that particular chart by following these instructions:
[2018-08-14 22:38:37]
Sorry for the delay, Please see the link below for a screenshot.
http://www.sierrachart.com/image.php?Image=1534286132971.png
Please note that in Region 2, I am looking for TSI study to be on the right scale (currently set to User Defined between -1 to 1) and two Williams studies to be on the left scale (set to User-defined between -100 to 0).
Also, in Region 3, similar problem exists. MACD study in this case is set to automatic, which appears to be on the right scale and is correct. Two stochastic studies are set to User-defined but their scales somehow don't show up correctly on the left side. I think the left scale displays to be the same as the right side scale currently in this region.
Lastly, as I mentioned previously, somehow I can't seem to make the value format display for scales to be different than what's displayed in format for the actual prices (in this case, currency displays in.00000 format and this carries over to other regions even though I've selected the desired value format for each individual study overlay).
If you could help me with these problems, that'd be greatly appreciated.
Best,
Elaine
