Date/Time: Tue, 21 Jan 2025 04:17:07 +0000
how to plot future date's value on chart using spreedsheet funtion
View Count: 710
[2018-08-01 15:57:51] |
User567294 - Posts: 47 |
I want to plot future day's value, for example, next 2 weeks, every day's value, plot on chart. how can I do that using spreedsheet? thanks Rex |
[2018-08-01 17:19:22] |
You cannot. This can only be done by using ACSIL.
[2018-08-01 17:34:56] |
can you point it to me? where to start? thanks Rex |
[2018-08-03 01:55:10] |
Yes refer to these two sections: Advanced Custom Study Interface and Language (ACSIL) ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].ExtendedArrayElementsToGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
