Date/Time: Tue, 21 Jan 2025 04:15:25 +0000
How to uninstall
View Count: 8353
[2018-08-01 13:58:47] |
User498240 - Posts: 1 |
I inadvertently pressed yes rather than no on the welcome screen when I first installed sierra chart. I want to uninstall and start again, but Windows 10 does not show it on the program list. Is there some other way to uninstall the program.
[2018-08-01 18:30:04] |
This is explained here: Software Download: Uninstalling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
