Date/Time: Tue, 21 Jan 2025 04:10:36 +0000
Sierra chart keeps closing/ quitting
View Count: 700
[2018-08-01 12:54:45] |
User465417 - Posts: 12 |
Hello, I started to experience this problem just now, my chartfile use to open flawlessly. But now whenever i try to open it, and it is in the middle of loading the chartbook, sierrachart just closes and quits, and then i have to reopen the application again and still the same issue. Please help? I even updated to the latest version and am still experiencing this problem. Thank you |
[2018-08-01 17:25:09] |
The first thing that we want you to do is to run Sierra Chart in Safe Mode and do not use an existing Chartbook and just open a single chart and see if you have a problem. Refer to: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
