Date/Time: Thu, 23 Jan 2025 04:58:05 +0000
Suggestion to add "Current traded BID/ASK Volume background" option
View Count: 1086
[2018-07-31 13:57:17] |
User515395 - Posts: 3 |
Hello, I am very satisfied with SC overall. Just wanted to ask if it would be possible to add Current traded BID/ASK Volume background.
[2018-07-31 18:05:00] |
We will look into this.
[2018-08-01 06:19:00] |
Cheers! I would imagine it just like the "Recent Bid/Ask Volume Background" where only the currently traded bid or ask is highlighted, when it´s traded. This way it would make the most sense to me. Would make it easier to keep focus on the recent column.
[2018-11-15 17:42:29] |
This is supported: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
