Date/Time: Wed, 22 Jan 2025 12:49:54 +0000
limit order ES- trade YM
View Count: 1191
[2018-07-31 08:05:28] |
stephane1 - Posts: 112 |
Hello, I want to place some limit order on the ES but trade on the YM when these limit orders are reached. Is it possible ? best Date Time Of Last Edit: 2018-07-31 08:06:33
[2018-07-31 08:13:50] |
For one user we did create this study: "Trading: Triggered Market Order for Trade Symbol" It is an undocumented study but from what we see you set a trigger price and then a market order is sent for the Trade and Current Quote symbol: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) We know the information given here is really not sufficient documentation. The main point is just to mention what we have and then we can see about documenting it. But it should do what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-31 08:20:44
[2018-07-31 09:04:10] |
Two questions: 1-Replay doesn't work ? 2- How can I show orders and positions onto YM chart (trade symbol)? best |
[2018-07-31 13:02:07] |
I can't use the "trade chart dom" onto ES, doesn't work.
[2018-07-31 16:11:25] |
I use realtime multiplicator but can I use correlation factor for more precision ?
[2018-07-31 18:37:32] |
Marmany - Posts: 307 |
Set chart to ES. In Chart Settings enter YM in Trade and Current Quote Symbol box. Job done! More detailed description in the online manual |
[2018-07-31 18:58:07] |
yes I did, now I would like an price line onto ES chart that's correlated onto YM. best SR Date Time Of Last Edit: 2018-07-31 19:04:30
[2018-07-31 19:03:14] |
oTher think!, I want to place order limit onto ES chart, I believe that's impossible if the price ES is more far that a price YM? I used "real time price multiplicator" in "advanced 2", but it's not precise (correlation beetween ES and YM). Will there be any solutions ? best SR Date Time Of Last Edit: 2018-07-31 19:08:33
[2018-08-01 06:21:03] |
You will have to place an order type which executes at market.
[2018-08-02 01:02:03] |
We need some time to prepare documentation. Allow us about 10 days. We cannot respond further until we have that done.
[2018-08-15 18:33:09] |
John - SC Support - Posts: 37369 |
"Trading: Triggered Market Order for Trade Symbol" does work during a chart replay. 2- How can I show orders and positions onto YM chart (trade symbol)? The documentation for the Trading: Triggered Market Order for Trade Symbol has been completed and can be found here: Order Types: Triggered Market Order For Trade Symbol Refer to this documentation to place the trigger on the ES chart and then have it place a Market order for the YM. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-29 11:28:42] |
Hello, Works fine, but now.....Is it possible to place YM market order when a setup appears on EM? for exemple I need to backtest different setup on ES and analyse trade statistic on YM. TKU SR |
