Date/Time: Tue, 21 Jan 2025 04:10:32 +0000
TradeStation Simulated Account
View Count: 2314
[2018-07-31 03:51:57] |
Joseph Keller - Posts: 19 |
Hello, what are the steps to link SierraChart to my TradeStation Simulated trading Account?
[2018-07-31 05:03:36] |
Sierra Chart does not support a link to trade station. What did you require from your simulated trading account? Did you want to use the market data? Sierra Chart has its own full trade simulation capabilities. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-31 15:41:44] |
How can I set up my chart to use Sierra Chart's data? Is it delayed?
[2018-07-31 17:36:13] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Real-time data is available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-31 17:36:32
[2018-07-31 20:15:00] |
Hi, I am interested in the SPY (stock), and ES (E-mini) right now. Is this available via the "SC Data - All Services" ?
[2018-07-31 20:25:33] |
I have a TD Ameritrade account, but want to learn Sierra under a simulated mode. My TD Ameritrade Thinkorswim platform allows this. How can I do this? TD Ameritrade referred me to Sierra.
[2018-07-31 21:08:59] |
See previous question...I also want to add SPX to the list
[2018-07-31 21:41:22] |
The title bar of my Window says "[ESU18 5 MIN #3 Symbol not found (Sep18)]" The chart loaded data but the title bar say "Symbol not found"?
[2018-07-31 22:21:05] |
Okay you are going to require real-time futures data and that will be reasonable being you have a TD Ameritrade account. So you are going to need to pay for and activate this data feed: Sierra Chart Exchange Data Feed You will need to activate this exchange: CME with Market Depth for nonprofessional Trading accounts 5.25 USD/month in addition to the real-time connection cost which will be 25 USD a month. The real-time US equities data will be available with the TD Ameritrade feed directly without an additional cost. Here are the TD Ameritrade set up instructions: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions Here is the documentation for Sierra Chart Trade Simulation Mode: Trade Simulation In regards to SPX are you referring to the S&P500 cash index? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-31 22:21:41
[2018-08-02 20:07:25] |
OK, I set up my SC per the TD Ameritrade set up instructions. But I am not seeing the 5 minute candle stick being written live. The time on the chart is an hour or so behind. For example, my chart shows 15:15 and it is 16:00 in New York. This is the same for the following symbols on my charts: $SPX, SPY. In my other ESU18 chart, the time shows 14:50 and its 16:00 in NY.
[2018-08-02 21:07:52] |
You certainly are not going to get any real-time data for cash indices or futures because you never activated the Sierra Chart Exchange Data Feed and we will not provide technical help if you are having trouble with the TD Ameritrade feed itself. So the very first step is going to be to activate the Sierra Chart exchange data feed and activate the necessary exchanges. Complete documentation is here: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-03 03:40:11] |
I paid for 3 months of SC service and received the following message: -Notice: Your Services Balance of 56.00 USD is too low to renew the Services activated on your account when they expire. You need a balance of at least 63.36 USD. What services is this referring to? All I needed at this point was the Standard Service Package, which includes real-time Forex - correct? |
[2018-08-03 04:16:20] |
One thing we see is that you enabled an additional system. For a total of 3 systems. Do you want us to disable that? Actually we see that you already did disable it. But it is active until September 3. Yes real-time Forex and CFD and crypto currency data is included. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-03 04:20:05
[2018-08-03 05:07:25] |
OK, so I am paid up for the chart service that includes Forex for 3 months? How do I enable the real-time data for Forex from you to trade to my TD America account, at the same time?
[2018-08-04 00:47:09] |
Yes this is the case and we have ensured your account now has the three additional months. We have confirmed that the Forex symbols are provided when you are using TD Ameritrade. You will see them in File >> Find Symbol >> Forex/CFD. And we apologize for the delay with the response. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-04 00:47:30
