Date/Time: Tue, 21 Jan 2025 04:19:30 +0000
[User Discussion] - Rate of Change - Percentage Study and Negative Values
View Count: 933
[2018-07-30 16:16:56] |
User41727 - Posts: 124 |
When dealing with negative values as inputs, the RoC% study returns the wrong output. As an example, let the input value at n-1 be -2 and -3 at n. Then the actual output will be 0.5 whereas it should be -0.5. |
