Date/Time: Tue, 21 Jan 2025 04:17:53 +0000
not able to connect to bitmex
View Count: 599
[2018-07-30 16:16:45] |
User13065 - Posts: 6 |
I was able toconnect no problem 7 months now unable. it just keep on trying to connect
[2018-07-30 17:11:43] |
Update Sierra Chart to the current version: Software Download: Fast Update And then follow through the step-by-step instructions here: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-30 17:13:04
