Date/Time: Tue, 21 Jan 2025 04:12:36 +0000
Trade Activity Log - 1 order displayed multiple times
View Count: 706
[2018-07-30 16:15:25]
User215298 - Posts: 20
Hello team,
I have the same order in the Trade Activity Log - Trade Stats for Chart displayed 4 times since I have 4 charts with 4 timeframes open. Is there any way to have the order displayed only once?
Kindly refer to the screenshot if it can help:
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=20887
[2018-07-30 17:49:07]
In newer versions, all charts that maintain a trade list are now displayed so they are visible since they can have different order fill starting times as controlled with this setting:
Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu)
Date Time Of Last Edit: 2018-07-30 17:49:46
[2018-07-31 05:09:25]
I see, thank you. So just for my understanding, if I start adjust the settings, is there a way to display just one order for symbol?
Thank you!
[2018-08-06 08:37:40]
Just wanted to follow up on my last question, trying to understand whether, if I dig into the settings, it is possible to have only one symbol displayed in the "Trade Activity Log - Trade Stats for Chart" or will I have always N duplicates where N is the amount of charts open (please refer to my inital screenshot posted).
[2018-08-06 10:46:59]
user8888 - Posts: 159
@User215298, totally feeling your pain. I have 4 markets in 1 chartbook with 8 chart per market, so now I have more 30 duplicated entries showing the same.
so much for the 'improvement'
look at the answer they gave me when I asked about this: TAL - Trade Stats for Charts
I don't even use the TAL for this purpose anymore
Good luck
[2018-08-06 10:52:59]
@sctr4d3r thank you. Looks like the TAL is no longer of use then unfortunately.
Shame cause looked like the only easy access tool to get an idea of all the open positions with no need to code a specific one.
I am wondering how many other traders are feeling this pain right now and who really is benefitting from having 30 duplicates.
Cheers
