Date/Time: Tue, 21 Jan 2025 04:10:06 +0000
Price axis on chart
View Count: 1403
[2018-07-30 15:15:54] |
User716575 - Posts: 24 |
Hi, I would like to reduce the price range on a chart. I'm referring to the price axis on the far right of the chart. Its showing a range of 80 ticks. I would like to reduce it to 40 or 50 ticks. I'm hoping this will increase the size of the candle bars. The bars are to small. John |
Attachment Deleted. 2018-07-30_0952.png / V - Attached On 2018-07-30 15:15:23 UTC - Size: 77.92 KB - 307 views |
[2018-07-30 15:26:01] |
Sawtooth - Posts: 4157 |
One solution is to go to each study on the chart and set the Scale to 'Same As Region'. This will cause the studies to only show within the range of the displayed price bars. Then right click on the price axis to select/adjust the displayed range. |
[2018-07-30 16:20:36] |
Thanks tomgilb, How would I go into each study and set to scale? Having trouble doing with that. |
[2018-07-30 16:39:23] |
The first thing you need to do is reset the scale (Chart >> Reset Scales)and determine what the Scale Range Type is currently set to. All of this is documented here: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-30 16:39:42
[2018-07-30 16:43:08] |
Go to Analysis >> Studies >> highlight a study in the list >> Settings >> Settings and Inputs tab >> Scale button
[2018-07-30 20:39:14] |
Thanks for the help
