Date/Time: Tue, 21 Jan 2025 04:20:21 +0000
More then one order via spreadsheet trd
View Count: 789
[2018-07-30 14:41:58] |
User513228 - Posts: 41 |
Hi, Im using automated trading via spreadsheet and Attached orders. I want ask if is possible send more then one limit order when i get signal ? For example i set up actual bid/ask as price for limit orders. But is possible automatically send another order 10usd higher or lower ? I know its possible set first order lower/higher with formula =J14*0.001+J14 but i want one order for actual price and second order lower |
[2018-07-30 15:12:50] |
Sawtooth - Posts: 4157 |
Not easily. The J22/J24 formula would need to return 2 different prices at 2 different times, and you'd need a new signal in K3/M3 for each. |
[2018-07-30 17:38:08] |
You really need to use the ACSIL trading functions for this and not the Spreadsheet System for Trading study: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-30 17:46:03
[2018-07-30 18:17:33] |
but this is not easy when im not programmer. Can i use ASCIL just for sending second order or i need make complet trading system ?
