Date/Time: Tue, 21 Jan 2025 04:14:18 +0000
[Locked] - 1785 ?
View Count: 1843
[2018-07-30 11:24:51] |
zippyzip - Posts: 293 |
updated to new build this morn and only have 1 price on bid ask , thanks you in advance
2018-07-30_07h23_16.png / V - Attached On 2018-07-30 11:24:35 UTC - Size: 15.86 KB - 299 views |
[2018-07-30 11:31:01] |
i went back to 1781 and seems to be a SC issue on data as i have cqg up and running and dom is fine on there end
[2018-07-30 15:37:38] |
This would be a CQG issue to resolve. Definitely not ours.
[2018-07-30 16:45:46] |
how can u blame cqg when cqg is fine and its only on SC im having issues along with others
2018-07-30_12h45_29.png / V - Attached On 2018-07-30 16:45:40 UTC - Size: 8.47 KB - 302 views |
[2018-07-30 17:15:14] |
We are going to blame CQG on this massively. This is not our problem at all. Dammit. Do not argue with us. We are not idiots.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-30 17:15:43
[2018-07-30 17:15:59] |
We are sick and tired of this crap. Do not bother us about this. Totally sick and tired. God dammit. This is a bunch of crap nonsense. CQG problems, Interactive Brokers problems. We do not give a damn about this stuff any longer. This is not worth our time. And then you post the version number at the top of this post and make it look like something is wrong with 1785. Why do you think we get upset about that. We are locking this thread. We do not want to hear about it from you or anyone. Also, we checked market depth data for F.US.CLEU18 from CQG. And it looks completely proper to us. So obviously if you see a problem it is connection specific. You cannot come to the conclusion that there is something wrong on the Sierra Chart side . That makes utterly no sense whatsoever with what we know about how that data is processed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-30 17:33:06
[2018-07-30 17:36:09] |
Also, if you want to post our messages on other forums on the Internet, please do and make sure though you take the current content as of this moment because there were some dictation errors previously which were corrected.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-30 17:36:21
