Date/Time: Tue, 21 Jan 2025 03:58:53 +0000
VWAP-Rolling ...
View Count: 776
[2018-07-30 09:47:20] |
bigFish56 - Posts: 7 |
Hi Guys, I cannot get VWAP-Rolling to configure as I would like. I have my charts setup to show both Day and Evening sessions. This is what I want. Unfortunately, if I display both sessions VWAP-Rolling resets at the start of each evening session. I realize that I can go to chart settings and disable the evening session during day session hours but this is annoying. What I would like is for VWAP-Rolling to reset and the start of each session, both day and evening. Are you able to to add this feature to the VWAP-Rolling study. regards James |
[2018-07-30 17:52:57] |
We could add this but it is not likely to be anything we would get to anytime soon.
