Date/Time: Tue, 21 Jan 2025 04:22:36 +0000
I noticed my CLEU18 feed changed
View Count: 716
[2018-07-30 06:49:01]
Grateful55 - Posts: 32
I was wondering if my feed changed trough you guys or AMP I don't mind paying a little more for a better feed and to be able to use the CTS that I have through you guys and just use AMP as a broker I talked to AMP the have me set on CQG
I'm new to this and really like your platform more than the others I've seen I'm just trying to figure out how to get it all working in sync or is the CTS not going to work since I have it through you instead of AMP I will re add the exchanges as well if that is what got thrown off tonight
[2018-07-30 07:30:56]
What exactly is the problem you are having? If there is something obviously wrong in a chart, post an image of a chart following these instructions:
CTS is supported whether you are using AMP as a broker or not.
Date Time Of Last Edit: 2018-07-30 07:32:21
[2018-07-30 07:38:02]
I got it figured out I had to add another data connection for it too work but it cost $35 on top of the $10 CTS plus platform fees for TPO but it does work thank you and sorry I didn’t notice that before
