Date/Time: Tue, 21 Jan 2025 04:00:27 +0000
Not receiving market depth and resting order data?
View Count: 1476
[2018-07-30 06:47:19]
TrumpTradesOil - Posts: 8
I'm not receiving market depth and resting order data into my charts.... I'm not sure what's going on. I have CQG Data.
[2018-07-30 07:49:39]
So is the chart updating in real time but you are just getting only a single level of market depth? If so, contact your broker and have them activate the market depth data for the particular exchanges that you need.
[2018-07-30 13:24:04]
User268341 - Posts: 15
I am having the same problem with CQG today.
[2018-07-30 14:52:44]
Infinite - Posts: 134
Yep CQG or someone must be having a BAD issue. I am having large gaps in the DOM and 4 point spreads, and then it clears up.
[2018-07-30 19:12:45]
If you still have a problem, we want you to reconnect to the data feed:
[2018-07-30 21:46:48]
There was indeed a problem with CQG data feed today after talking with amp futures. They said there was a data feed problem since trading begin this morning.
[2018-07-30 22:06:38]
Are you noticing any problem with market depth at the moment with CQG? We are not. But we only tested September CL crude oil. Which is a good test for us because that provides more than 10 levels of depth.
