Date/Time: Tue, 21 Jan 2025 04:08:06 +0000
Question on Bar Position
View Count: 663
[2018-07-30 03:06:38] |
Quantico - Posts: 45 |
I use number bars and also have a volume profile on the left side of my charts. Sometimes I like to look at just one or two days of bars but when I change the chart settings to x number of bars, the one or two bars I want to view smash over to the left side of the chart and obliterate the volume profile. Mouse scrolling only increases or decreases bar width and of course dragging the bars to the right is impossible. I can lock the fill on the right side of the chart but cannot see a setting for filling the left side. Any help please? Thanks in advance. Date Time Of Last Edit: 2018-07-30 15:09:46
[2018-07-30 16:40:31] |
The best you can do is align the Volume Profile to the right: Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
