DTC Protocol Discussion Forum
- DTC Protocol Discussion Forum |
 - Search Board |
 - Control Panel |
 - View My Posts / Threads |
 - Direct Messages
Date/Time: Tue, 04 Nov 2025 15:12:39 +0000
Is study & indicator data available via DTC?
View Count: 3471
|   [2018-07-30 00:44:11]     |
| User443067 - Posts: 2 |
                In the list of pre-defined messages there is no mention of accessing studies or indicators. Is it possible to access this data via DTC? If so, how?  Historical data only, not real-time. As an example, I'd like 1-minute based VWAP data in addition to OHLC. Sierra Chart is very efficient at rebuilding an enormous tick-by-tick history. If this data is not accessible then tick data must be requested via DTC, compute the VWAP, re-sample to a lower resolution, and throw away the tick data. It would be far more efficient to compute inside Sierra Chart.  |
|   [2018-07-30 01:01:39]     |
                No, the protocol does not support study or indicator data.
|   [2019-01-26 08:02:10]     |
| uM8137 - Posts: 183 |
                Could one define one's indicator as a novel but "fake" symbol with the indicator conveyed in the price value? For example, requesting ticks for symbol "SMA100_1min:@ES" could return the 100-period 1-minute sampled simple moving average of @ES.  |
|   [2019-01-27 05:13:45]     |
                Sierra Chart is capable of this. You will want to use the Sierra Chart  Support Board for guidance for how to do this.
