Date/Time: Tue, 21 Jan 2025 04:11:54 +0000
Acsil historical intraday high/low
View Count: 1579
[2018-07-28 15:47:20]
User704990 - Posts: 18
Looking for a acsil function to access intraday high/low historically. I tried using SCFloatArray
SubgraphArray but the data points from the Daily OHLC study don't seem to be accessible.
Any suggestions?
[2018-07-28 20:00:14]
Have a look at this function and the one listed below it:
sc.GetOHLCForDate()
[2018-07-28 21:43:45]
Any specific reason the data points from the Daily OHLC study wouldn't be available to access via acsil?
[2018-07-28 22:40:56]
Not sure we understand the question because that function we linked to above does exactly that and you can also refer to this section here:
ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function
[2018-07-28 22:58:09]
It didn't seem as if I could access the day high/low looking back 1 to 2 bars if a new high or low was made after that (current bar)
[2018-07-29 00:21:43]
If you cannot do what you need with those ACSIL functions, then just reference the Daily OHLC study as explain here:
