Date/Time: Tue, 21 Jan 2025 04:22:16 +0000
Reversal Bars + Numbers Bars drawing errors
View Count: 916
[2018-07-27 22:30:01] |
rabbitTrader - Posts: 16 |
I'm experiencing drawing errors using a reversal bar type with the numbers bars study. All symbols with errors (ADAU18-BMEX, BCHU18-BMEX, EOSU18-BMEX, TRXU18-BMEX, XRPU18-BMEX) are BitMEX instruments. It seems that the numbers bars are drawing 12 ticks higher than they should. In the screenshot linked below, you can see a correct candlestick chart on the right with the errant numbers bars chart on the left. Note the low of 0.00002076 on the numbers bars that should correspond to the low of 0.00002064 on the candlesticks. http://www.sierrachart.com/image.php?Image=1532730074136.png Thank you. |
[2018-07-28 04:01:49] |
Refer to the information here about this: Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols We cannot provide further help other than what is documented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-28 04:03:20
