Date/Time: Tue, 21 Jan 2025 03:57:13 +0000
What does it means to have 67p on the P/L?
View Count: 760
[2018-07-27 16:06:58] |
User312948 - Posts: 18 |
What does it means to have 67p on the P/L, it don't really add up to my trade I finished.
[2018-07-30 16:45:36] |
This is documented here: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) You really should not use a setting which is ignoring the quantity. Also refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-30 16:45:57
