Date/Time: Tue, 04 Feb 2025 02:54:30 +0000
How to 'Enable' (or Disable) BUY Market or SELL market at the DOM?
View Count: 1111
[2018-07-27 15:25:05]
Programming_autotrading_phonesup - Posts: 59
In the Trade Window Controls you can Enable (or disable) most of the Controls (see screenshot) but I could not find a way to disable the BUY MKT and SELL MKT buttons.
Is there a possibility to do so? I would like to disable those two buttons.
imageVirtualBox_WIN10 Trading And Backtesting_27_07_2018_11_13_00.png / V - Attached On 2018-07-27 15:24:04 UTC - Size: 61.5 KB - 320 views
[2019-12-28 09:11:35]
User784341 - Posts: 6
I have the same request.
[2019-12-29 04:27:19]
We have to add options for these.
[2019-12-29 13:49:57]
User205938 - Posts: 8
There is a simple solution:
1. Remove the Trade Window from the DOM
2. Modify your Chart DOM settings to your specific needs.. ie. to prevent you from marketing in or out.
3. I would still setup a 911 key to flatten all positions in case of emergencies.
If you still need the daily PnL or position PnL there are studies you can add to the DOM that show you those. Self-control is a pain sometimes, but its best to remove all temptations. lol
