Date/Time: Tue, 21 Jan 2025 00:57:24 +0000
Loop when adding 2nd Large Volume Trade indicator
View Count: 559
[2018-07-27 08:59:12]
Andrey - Posts: 8
if I add on a chart the second Large Volume Trade indicator the application loads data files without end until I remove one.
Please tell how to solve this.
thank you
CL-201809-NYMEX Rev. 10t-10 #10 | Reloading chart. | 2018-07-27 11:44:31
+ Loading market depth data. | 2018-07-27 11:44:32
Loaded depth data records for CL-201809-NYMEX 2018-07-17 from 2018-07-17 18:33:54 to 2018-07-18 00:00:01. | 2018-07-27 11:44:32
Loaded depth data records for CL-201809-NYMEX 2018-07-18 from 2018-07-18 10:06:21 to 2018-07-18 12:18:53. | 2018-07-27 11:44:32
Loaded depth data records for CL-201809-NYMEX 2018-07-23 from 2018-07-23 12:59:14 to 2018-07-24 01:05:39. | 2018-07-27 11:44:32
Loaded depth data records for CL-201809-NYMEX 2018-07-24 from 2018-07-24 11:46:12 to 2018-07-25 00:00:01. | 2018-07-27 11:44:32
Loaded depth data records for CL-201809-NYMEX 2018-07-25 from 2018-07-25 12:37:45 to 2018-07-26 01:11:16. | 2018-07-27 11:44:32
Loaded depth data records for CL-201809-NYMEX 2018-07-26 from 2018-07-26 08:48:20 to 2018-07-27 01:10:10. | 2018-07-27 11:44:32
Loaded depth data records for CL-201809-NYMEX 2018-07-27 from 2018-07-27 11:10:11 to 2018-07-27 11:44:05. | 2018-07-27 11:44:32
[2018-07-27 16:35:18]
More than one instance per chart is not supported. This is explained in the documentation here:
Large Volume Trade Indicator
