Date/Time: Tue, 21 Jan 2025 04:18:15 +0000
Market Depth Data Not Displaying
View Count: 1097
[2018-07-26 23:11:44]
User1990 - Posts: 49
I've recently subscribed to Full CME Exchange Data feed with Market Depth (currently on trial version). I've added market depth historical graph to my Studies setting and followed the instructions on Sierra Chart website for adding market depth data Market Depth Historical Graph but i cannot get the data to display. Can you help me look into this problem?
Thanks a lot for your help,
Regards,
Elaine
[2018-07-27 00:14:28]
Provide an image of the chart or Trade DOM which contains the Market Depth Historical Graph study, by following these instructions:
Date Time Of Last Edit: 2018-07-27 00:15:00
[2018-07-27 00:37:23]
http://www.sierrachart.com/image.php?Image=1532651811482.png
the market depth historical graph studies doesn't seem to show up at all.
Thanks a lot for your help.
Elaine
[2018-07-27 17:22:03]
It looks like it is there but the color settings may not be correct.
We want you to reset the Market Depth Historical Graph Study to its default settings following these instructions:
Chart Studies: Resetting Default Study Settings For an Individual Study
Remove it from the chart and then add it again and do not change any Input settings for it at this time.
[2018-07-27 22:30:45]
I reset the study like you outlined and it shows me a log like below:
I am not sure what is going on because i can see real-time market depth data during trading hours when i open the market depth window like the one i sent you in the image a few threads above. Is it because I may be on the trial version?
Loaded depth data records for CLU18 2018-07-26 from 2018-07-26 17:27:23 to 2018-07-26 19:59:59. | 2018-07-27 18:23:57
Loaded depth data records for CLU18 2018-07-27 from 2018-07-26 20:00:00 to 2018-07-27 16:59:57. | 2018-07-27 18:23:59
Loaded depth data records for CLU18 2018-07-27 from 2018-07-26 20:00:00 to 2018-07-27 16:59:57. | 2018-07-27 18:24:00
Market Depth Historical Graph | Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2018-07-27 18:25:40 *
Market Depth Historical Graph | Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2018-07-27 18:26:30 *
Market Depth Historical Graph | Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2018-07-27 18:26:31 *
[2018-07-28 00:59:37]
We apologize. We did not notice that your account is on service package 3. The Market Depth Historical Graph requires service package 5 (Advanced). Follow the instructions below:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
We also activated a trial on your account for the advanced service package, so no need to do anything at the moment.
Date Time Of Last Edit: 2018-07-28 01:00:07
