Date/Time: Sun, 24 Nov 2024 08:43:58 +0000
Standard studies such as moving averages are not listed in the studies available list
View Count: 1354
[2013-10-18 09:47:46] |
ChrisR - Posts: 7 |
I am a trial user, however I cannot access studies such as moving averages, momentum, Bollingers etc as they are not listed in the studies available list under Analysis -> studies I have the more advanced studies listed such as TPO and Volume by price etc, but not the standard ones. Am I doing something wrong? Thanks |
[2013-10-18 10:25:23] |
This does not make sense. Exit from Sierra Chart and install it again using this link: http://www.sierrachart.com/index.php?l=doc/download.php#download Do not change the installation folder. Use the default of C:\SierraChart. We have noticed that you have installed Sierra Chart to your system desktop. This will only clutter the desktop and we do not know what kind of problems that will cause. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-18 10:25:46
[2013-10-18 11:03:59] |
ChrisR - Posts: 7 |
Interesting. I had installed SC into C://SierraChart on Windows 8. Anyway I deleted that install and reinstalled SC again into the same directory and it works fine. All the studies are now there. Thanks for your help. |
