Date/Time: Tue, 21 Jan 2025 00:54:27 +0000
Tick by Tick vs 1 second Data Configuration efficiency
View Count: 1281
[2018-07-26 10:21:23] |
User434975 - Posts: 2 |
while reading Tick by Tick Data Configuration This came up.... Keep in mind that tick by tick data is less efficient and takes more disk space. However, it is necessary for accuracy.
Could u mind explaining, How tick by tick data is less efficient ?i want to see the market working in 1000th of a second, i guess tick by tick seems only possible way.... Thanks sierra chart for creating wonderful ACSIL Platform. |
[2018-07-26 18:46:15] |
We updated the documentation to make that more clear. However, the setting you are really interested in is the Chart Update Interval: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-27 09:02:20] |
Thanks for Clarification. I want to see ticks in 1 millisecond range. Do i need to change to this ? ChartUpdateInterval = 1
Anyways, I have a old 32 bit windows system with following details, will it work ? Machine name: JAIBHAIRAVI786M
Operating System: Windows 10 Pro 32-bit (10.0, Build 17134) (17134.rs4_release.180410-1804) Processor: Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20GHz (2 CPUs), ~2.2GHz |
[2018-07-27 12:17:52] |
Cavalry3162 - Posts: 523 |
1ms is too much and just eats through your pc's resources.. 20 is good enough.. humans need 100-200ms to react.. |
[2018-07-27 16:19:17] |
This is all explained here: General Settings Window: Chart Update Interval (Global Settings >> General Settings >> General >> Update Intervals) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
