Date/Time: Tue, 21 Jan 2025 00:51:47 +0000
[User Discussion] - chart data problem
View Count: 825
[2018-07-26 09:49:22] |
User583186 - Posts: 1 |
Hi I'm TransActFutures customer I trading from Algiers Algeria mhat time do I need to set my intraday charts my data is delayed I have to reload my 5mn chart every minute please help |
[2018-07-26 18:47:37] |
If the data is delayed you need to contact Transact support about this. Your broker can put you in contact with them. If you want to set the time zone, refer to: Time Zone Setting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
