Date/Time: Tue, 21 Jan 2025 00:55:20 +0000
linking alert conditions from one chart in a chrtbook to another
View Count: 1062
[2018-07-25 16:12:33] |
Glenn Infinity - Posts: 103 |
is it possible to transpose an alert condition programmed in one chart in a chartbook to another chart? Can they be linked like the studies? or be copied from one chart to another? if so are there criterion to be met? Must the charts be similar in nature? Or do the alert conditions need to be programmed in to each chart?
[2018-07-25 17:04:50] |
You cannot do this across Chartbook's but you can do it within the same Chartbook by using Chart Linking and linking the Chart Studies: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-25 18:44:31] |
User477191 - Posts: 10 |
When I link my two charts nothing happens. Do the charts need to be similar in nature?
[2018-07-25 19:10:20] |
No they do not have to be similar, make sure they have the same Link Number and both should also have the Studies linking option enabled as well. Refer to: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber So when you change studies on either of the charts, including the alert condition, those changes will be applied to the other charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-25 19:12:07
[2018-07-25 19:23:20] |
I configured correctly and it did not work.
[2018-07-26 16:57:27] |
Tell us specifically what you are expecting to happen.
