Date/Time: Sun, 24 Nov 2024 08:51:07 +0000
Multiple copies of Sierra Charts
View Count: 1399
[2013-10-18 08:04:50] |
User41512 - Posts: 58 |
Hi, Can i run 2 copies of Sierra Charts, on the same computer at the same time, using 2 different data providers.ie 1 copy open which is using IQ feed, and another copy open using a different data provider? Thks |
[2013-10-18 08:39:39] |
Yes you can. Here are instructions for this: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
