Date/Time: Tue, 21 Jan 2025 00:56:39 +0000
getting rithmic data into open office spreadsheet
View Count: 715
[2018-07-24 19:39:01] |
User69393 - Posts: 6 |
asking for directions placing rithmic pro data into OPEN OFFICE spreadsheet. or if you know of another dats source for open office spreadsheet, let me know can you help getting sierra chart data, rithmic pro data, or another data feed into open office spreadsheet? thanks |
[2018-07-25 17:23:13] |
You are able to export the data from a Sierra Chart chart to a text file. Here are the instructions for that: Edit Menu: Edit >> Export Bar and Study Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
