Date/Time: Tue, 21 Jan 2025 00:58:37 +0000
ACSIL - query alert state
View Count: 564
[2018-07-24 14:00:37] |
cross - Posts: 70 |
Hello, Inside an ACSIL indicator is there any way to query the state of the alert (which is set on the Alerts tab in indicator settings)? Or can I evaluate a string in the way an Alert is evaluated? Thanks |
[2018-07-24 18:08:27] |
Yes. Refer to: ACSIL Interface Members - Variables and Arrays: sc.AlertConditionFlags Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
