Date/Time: Tue, 21 Jan 2025 00:47:44 +0000
cpp works well, I have a recurring error in the
View Count: 836
[2018-07-24 11:26:02] |
User210074 - Posts: 63 |
Hello. I have a problem with my cpp. It works well. But today, I have an error message in the "LOG MESSAGE" that I can not solve. I put an example cpp and a photo capture. The message appears after 2 or 3 minutes after installing the CPP in the chart. Despite this message the CPP works well. Can you help me to fix this problem? |
Private File Private File |
[2018-07-24 17:45:44] |
Your code has a bug causing an exception. We do not provide debugging services. We recommend you use step-by-step debugging to determine what the problem is: Step-By-Step ACSIL Debugging Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
