Date/Time: Tue, 21 Jan 2025 00:45:34 +0000
Issue: ACS Buttons do not expand to size of button caption when set with sc.Set...
View Count: 641
[2018-07-23 21:26:29]
Richard Chinn - Posts: 28
For Your Attention. No response necessary unless I have overlooked something.
SETUP: Place ACS Button on control bar using ACS Button DEFAULTs. Note: The "Use Same Size for Control Bar Buttons" is NOT checked
Programatically set caption to a longer text string than the default:
  Note: I Also checked this by entering a Button Caption through the "Properties Button" in the "Customize Control Bar 1" window before changing it programmatically.
  My entry was "ACS1" The same error still occurred.
sc.SetCustomStudyControlBarButtonText( 1, "Longer text than default button caption")
OUTPUT ERROR: Button size does not change to accommodate the longer caption text string.
Documentation Search was unsuccessful.
Support Board Searched using the search term: "ACS Button". I did not see any threads relating this issue.
Thanks,
Richard
[2018-07-24 04:08:52]
We will look into this.
