Date/Time: Tue, 21 Jan 2025 00:59:40 +0000
Automated question - ignore alert or order during consecutive buy or sell alerts
View Count: 995
[2018-07-22 16:16:58]
User7817001 - Posts: 96
What is the most efficient method of ignoring consecutive alerts for buy or sell alerts, when already in a position?
Please see attached for alerts.
The plan is to enter n contract(s) manually, then run the automation, reversing the long to short, or short to long on 1st occurrence opposite alert.
So, after the 1st turn around alert, long to short for example, I will need the algo to ignore all other sell (red) alerts, and only trigger on next buy (green) alert.
thoughts?
Thanks,
Mark
imageCapture.JPG / V - Attached On 2018-07-22 16:16:48 UTC - Size: 185.34 KB - 284 views
[2018-07-22 17:00:46]
This is going to inherently be the case when this is set to No/false:
Automated Trading Management: AllowMultipleEntriesInSameDirection
Date Time Of Last Edit: 2018-07-22 17:00:52
[2018-07-22 18:25:04]
Sawtooth - Posts: 4157
You would need to use a spreadsheet study to create a persistent variable until the opposite alert occurred.
Here are some spreadsheet formula examples:
Spreadsheet Example Formulas and Usage: Persistent and Incrementing Variables
