Date/Time: Tue, 21 Jan 2025 07:46:20 +0000
Poc Ext line Name&value not showing on numbers bars
View Count: 1085
[2018-07-22 10:24:36] |
User657944 - Posts: 173 |
Hi Team I'm not able to have the Number Bars POC extension line Name And Value displayed, I have set the poc to be displayed and the end of the extension line and the value on values scale but it does not work. And friendly speaking it never works but I hop that with new release it will be fixed but it is not.While the non zero line extension works for the values and not for the name. Atteched find the chart and the relative settings. Thx |
Attachment Deleted. poc label settings.png / V - Attached On 2018-07-22 10:23:03 UTC - Size: 42.21 KB - 392 views issue name label poc.png / V - Attached On 2018-07-22 10:23:19 UTC - Size: 61.63 KB - 322 views |
[2018-07-24 08:39:40] |
Could you please answer at my case? It is an issue not a uder discussion thx
[2018-07-24 20:08:53] |
John - SC Support - Posts: 37327 |
We will look into this. We are a bit behind with other work at the moment, so it will probably be a little over a week before we can delve into this and determine what is happening and why and then make any necessary changes. We will post here with the information on when the change are complete. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-25 09:11:13] |
Thx guys
[2018-08-06 12:48:19] |
Hi Any updated about this issue?thx
[2018-08-06 13:12:50] |
We have not had a chance to look into this yet. Hopefully in the next week or two.
[2018-08-08 20:23:35] |
We have updated the Numbers Bars study and the Color Bar Based On Alert Condition for the Extension lines to use the controls on the Subgraph window. This change will be in the next release - 1787. The information on new releases is posted on the Main Sierra Chart webpage in the upper right hand corner. When the release is available, you can download it following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-09 08:10:22] |
Thx John
