Date/Time: Tue, 21 Jan 2025 00:46:12 +0000
trading keyboard shortcuts
View Count: 1174
[2018-07-20 21:57:20] |
User597265 - Posts: 1 |
Hi, it says that i dont have "trading keyboard shortcuts enabled" actually on, but it is and it still does not work. I reset the program and still doesnt work. can you help me with this?
[2018-07-23 03:50:10] |
That message also includes the name and number of the chart it relates to. Which chart is giving this error message?
