Date/Time: Tue, 21 Jan 2025 00:48:03 +0000
Data Feed Purchase
View Count: 660
[2018-07-20 21:16:54] |
User20202020 - Posts: 18 |
Hi, I’m trying to purchase a 500 feed data connection, but I keep get the following error messages: Failed to extend feature expiration date. Failed to create/reactive Account 150975_1 on the Barchart system. Failed to activate the Market Data Feed. I’m also attaching a screenshot. What do I need to do? |
[2018-07-23 04:18:59] |
This issue has now been resolved. Try reactivating the real-time connection and the number of symbols again. It was an issue on the Barchart side.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-23 04:19:10
