Date/Time: Tue, 21 Jan 2025 00:43:18 +0000
Issue w/ 5yr note futures volume data on DOM
View Count: 655
[2018-07-19 16:46:57]
User810183 - Posts: 2
Hi, I'm having issues with data on what i believe to be only affecting 5yr notes. I get depth but am unable to view volume on the DOM and unable to recenter. I've tested DOMS on most equity indexes, currencies, and energy but it only seems to be affecting the 5yr. Attached is a pic of what Im looking at. Any input appreciated. thanks
http://www.sierrachart.com/image.php?Image=1532018561572.png
Date Time Of Last Edit: 2018-07-19 16:47:49
[2018-07-19 19:17:21]
First thing we want you to do is to reconnect to the data feed:
And see if this corrects the problem initially. Must be a CQG data feed issue.
[2018-07-20 02:17:27]
Thanks for the timely response, After disconnecting and reconnecting it worked great for about an hour and then I came back to my desk and it was back in the same spot not loading volume and unable to recenter and stays that way when I disconnect/reconnect again
Date Time Of Last Edit: 2018-07-20 05:15:30
