Date/Time: Tue, 21 Jan 2025 00:43:36 +0000
How do I get rid of infinity futures sierrachart and alter back to original?
View Count: 1433
[2018-07-18 21:06:23] |
runningfree - Posts: 19 |
Infinity futures installed their own version of sierrachart and I am not enjoying it. When I try to load sierrachart now it says this: [img]https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=20629[/img] |
Untitled-22.gif / V - Attached On 2018-07-18 21:05:12 UTC - Size: 11.46 KB - 509 views |
[2018-07-18 23:08:04] |
That error message is very uncommon. The first thing we recommend you do is exit from Sierra Chart and any other instances of Sierra Chart you are running and start Sierra Chart again and see if you encounter that error message.
