Date/Time: Tue, 21 Jan 2025 00:48:38 +0000
Scroll back, how to keep the vertical axis numbers the same
View Count: 1134
[2018-07-18 17:00:28]
coin boss - Posts: 19
Its the most frustrating thing, having the numbers on the verticle axis (price), change when you scroll back. I want price to stay the same, so that when i scroll back im looking at the exact same level, (seems like it should really be default actually). I read this post: Horizontal Scrolling but that does not work using constant range and unchecking the recenter on chart scroll.. any ideas please and thanks.
here are current settings, where it still scrolls all over the place when i pan backwards on the horizontal axis.
imagetemp1.png / V - Attached On 2018-07-18 16:59:35 UTC - Size: 288.68 KB - 296 views
[2018-07-18 17:24:46]
What you can do is right-click on the price scale and select:
Scale Range: User Defined with Auto Set
If you are using a Constant Range Scale, then make sure the Constant Range Scale Mode is set to Manual Mode.
Date Time Of Last Edit: 2018-07-18 17:27:26
